What size box with these T/S parameters?
  • 4
chillin
Cubic feet, port size and tune? I'm still too much of a newb to understand what to do with these numbers, but I know some smart guys out there will know the answer.  I do have a recommended box from the owner of the company, but when he told me the numbers, I had limited space in my car, so not sure if they would stay the same since I can go bigger now.
[SIZE=11pt]Fs  = 39.91 Hz
Re  = 3.70 ohms[dc]
Qt  = 0.35
Qes = 0.39
Qms = 3.90
Mms = 250.57 grams
Rms = 16.100405 kg/s
Cms = 0.000063 m/N
Vas = 50.79 liters
Sd= 754.77 cm^2
Bl  = 24.398737 Tm
Lp(2.83V/1m) = 94.46 dB[/SIZE]
Supercrew f150, Rock, metal and rap for the most part. Right now i have a 1200 watt amp, may upgrade to 2500 in he future depending if I want more bass and want to spend the extra on electrical upgrades.
I don't have the truck yet, just looking for the future.  I don't mind taking up space in the back seat. The sub has been sitting in my basement for 8 or 9 years. bnib, plans changed and I never got a chance to use it, had to get something smaller, but I want to build a box for it that is correct for the sub.
The larger size will have slightly better low end extension but will be boomier sounding. The wide range is from the vague amp information.
So 4cf would be a nice middle ground for a little boom and still here double kicks on metal songs?
Thanks for all the answers btw, this sight is way quieter than when I used to frequent it.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
chillin
chillin
Whistler, Canada
chillin
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
