Subwoofer problem HELP!
  • 3
Dejan Blanuša
CarAudio.com Newbie
Hello! I know it is a long shoot, but I will try anyway...:)
I have a car audio unit Alpine CD-E103BT. It is great, but I have one little problem. When I turn off subwoofer on that unit in subwoofer options menu, subwoofer works, but, when I turn it on, subwoofer doesn't work. Do You know what could be the problem? Sub is connected via amplifier to the head unit.
Thanx!
Hey mate, so it works sometimes and when you turn on, it does not work.
Sounds like a loose remote (blue) wire issue but could also be the amplifier.  I suggest you check the following:
  • when you turn your stereo on, check if the amplifier switches on as well, if it does not, then most likely a loose remote wire connection;
  • if your amp goes on and the sub does not play, then it could be a loose connection inside the subwoofer box / subwoofer connection; check that out too!
  • Lastly, If the problem still persists, then you may be required to check your connections behind your Alpine unit; including the remote (blue) turn on wire that goes to your amp;
  • If the issue still remains, then it could also be faulty RCA cable as well, use a multimeter for resistance;
  • use multimeter to check subwoofer wiring as well so it gives you a clean reading before you take subwoofer out;
  • also check RCA connections behind the Alpine head unit and the amp as well;
Its only a minor issue and hopefully you will rectify it soon mate!  Good luck and let us know if its resolved.
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
Pick it off the floor while playing. If rattle goes away then it is fine. If not, bad sub.
Storage is actually pretty big ( but not big enough for an enclosure that's mounted on the door because it closes in an angle believe it or not...
15
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
219
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
Dejan Blanuša
CarAudio.com Newbie
Dejan Blanuša
DRBOOM
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
