Build help what am i missing?!
  • 3
Craigkleer
CarAudio.com Newbie
 Complete noob but love car audio ...
I would like my build to play at the optimal performance... what components am i missing
1 dm810 audiocontrol
8 x 6.5 faital pro
2x beymas bullit tweeters
2x kickers dome tweeters
2x stetsom 4 channel amp 800.4 for voice 4 chanels per amp
1x 400w stetsom 4 channel ...for 4 tweeters
1x clarion 3 way crossover
2 10 inch l7 with alpine amp bridged for each sub..
I was told to get 2 audiocontrol lc7is and 2 3 way crossovers for everything to play in stereo
Start by drawing how you want to wire all of the components you've listed.  Stereo wiring is pretty simple - keep right speakers on channels fed by right channel outputs, and similar for left.  What is the source unit (head unit/radio)?
8 x 6.5 faital pro
the two audiocontrol idea is dog sh*t idk why anyone would ever suggest that unless they are living under a rock for the past 10 years. Stick with your DSP idea. I'd take out the kicker dome tweeters, they will do more harm than good, just like its a horrible idea to mix match sub brands and sizes, you dont want to mix match tweeters as well because sound waves produced are different and will either join and become distortion or cancel each other out, aka it'll sound like complete sh*t. Those beymas should be more than loud and enough and sound good if you properly use the DSP crossovers, cross high like 8khz or so to tame the usual 5-7khz peak super tweeters have. If you have a DSP, you dont need any clarion crossover so take that out of the equation as well.  If you haven't bought the alpine amps yet, get a monoblock and run both subs off a single big amp.
What I'd recommend is swapping out 4 of those faital pros for dedicated midbass monsters because those faital pros dont really handle midbass all that well and to have a good sounding system, you definitely want strong meaty midbass. Make sure behind the doors, you seal off the midrange from the midbass with some kind of enclosure or foam pod. You'll let the midbass take up the whole door's airspace for its enclosure to increase overall midbass performance. You'll bridging the a 4 channel to the midbass, bridging a 4 channel to the midrange and bridging one for the tweeters.  Your audiocontrol dsp should have more than enough channels to do a 3 way active network setup plus subwoofer.
If you want to save money and dont care for factory head unit features, you can get a dayton audio dsp for 150 and a dayton bluetooth dongle for 30 dollars more. You stream audio straight from your phone bluetooth to the dsp without needing to splice into any thing from the factory head unit. The audio will be way cleaner than if you do high level inputs or RCA inputs. All tuning will be done on your smart phone app. Only drawback to this is no bluetooth calling while driving however audio results will be superb.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
839
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
777
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
7
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
Craigkleer
CarAudio.com Newbie
Craigkleer
Jeffdachef
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
