Foxxxycoxxxy
Bass junkie
- 14
You can: A get a sub that is 4ohm and run it on your amp. B you can get an amp that is 2ohm stable and run the sub with the coils parallel. C you can run the sub at 8ohms into your amp and get about 200watts of power.Ok thanks for the info. I'm guessing 8 ohm isn't the loudest way to run this sub do you have any opinions on how i should run it???...i have another jumper wire I could use too.
