Help deciding on a planned system in a 2018/2019 Toyota 4Runner Limited
  • 2
JamminJZ
Hi everyone,
Within the next year or two i will be purchasing a Toyota 4 Runner limited.
I plan to go full system replacement.
For the head unit I am looking at the Kenwood Excelon DNX995S.
For speakers i want to do 3 way components in the front. Debating between Focal, Hertz, Infinity,
For back doors and tailgate speakers i cant decide if I should go coaxal 2/3 ways or 2 way components.
I plan to reuse the factory sub location but with a better 8" sub.
I plan to run amps for everything and considering also running a Hertz Audio H8 DSP unit.
I am looking for good clean sound and I am picky about sound quality as I used to run large live sound for concerts ect.
Any input, advice, recommendations, insight all are welcome.
I also plan on adding sound deadening where needed.
Thank you,
Sounds like a good plan. I've had the Focal 165 AS3 system and wasn't overly impressed, the sound was a bit muddy. I currently have the Infinity Kappa Perfect 600 with the extra 300m mid, running 3-way. They sound amazing and are loud AF. I haven't heard the Hertz system, but they do have a good reputation regarding sound quality.
If running an 8 in the stock location, make sure the air space is adequate and the area is re-enforced. Most factory 8 inch subs aren't built for high excursion.
Good Luck!
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
  • Poll
Adire Brahma X is a well regarded good sounding low distortion woofer that can get loud and sound good doing it. Fi has some neodymium motor...
9
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
65
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
155
11
349
JamminJZ
JamminJZ
conneticut
aburger003
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
