Yes the speaker terminal block is from an old clarion its the only way I could find a replacement.
Yes those soldering irons had a hard time getting the terminals out of the boards.
I've already installed the terminal.
I find all these sites on the net, nobody wants to answer questions or emails.
I'd like to know where I can find an insulator for the mosfets, should I use kapton tape?
the offset current or bias voltage, whatever its called. what should it be set to?
Where are the test points?
As you can see I already replaced most the capacitors and the pin headers for the tube board.
The amp is working if I could find the info I just mentioned I could button it up and use it.
Zed doesn't repair US amps, it says it right on his page.
I guess this topic will be a dead end just like the 12 YEARS of threads all over the internet because these so-called proud builders and companies dont give a crap about the end user.
No wonder everything is made in China now, nobody wants to help fix this junk.
Why would US amps use LM caps?
Anyways I could use some help but it seems nobody wants to.
RE amps doesn't answer the phone, they dont return calls, they dont return emails.
Its ridiculous
