SQL for daily driving 12 inch ssa icon or fi ssd 15inch
Texas pipeliner_00
CarAudio.com Newbie
Hello
I need help guys I'm trying to get a sub for my chevy avalanche I'm removing the midgate and I have all the space in the world to put in a good enclosure..I'm planning on using a 1200watt amp. for electrical I'm keeping my stock alternator  adding a 3 g and replacing my battery to  a xs or optima..my goal is to get good sq with some output I'm not aiming towards being heard 3 blocks away I just want some good hard hitting clean bass that will play all types of bass notes..I listen to all types of music from rock metal alternative to rap..I been looking into a 12 inch ssa icon for 279 and  fi ssd 15 for the same price I need your guys opinion...what sub do you guys recommend and also can you explain why thank you
he said in the OP its because theyre the same price
Yeah well that just seems silly. I bet the 15" icon is only $40 more than the 12". What is $40? Its nothing lol but if its that important, definitely go with the Fi Ssd. Itd be silly to get 12" over a 15" if you have the room for the 15"
im sure he was also asking about qualitative differences between them since they are so close in price
I don't see a 15 inch icon in their website
10" ICON D1/D2
12" ICON D1/D2
15" ICON D1/D2
18" ICON D1/D2
Coil(s)
3" wide, 4 layer, copper coils
Terminals
Push terminals
Push terminals
Push terminals
Push terminals
Cone
Pulp Fiber Cone
Pulp Fiber Cone
Pulp Fiber Cone
Pulp Fiber Cone
Suspension
Dual stiff progressive spiders
Motor
FEA optimized motor
FEA optimized motor
FEA optimized motor
FEA optimized motor
Former
3" Anodized alum. former
Lead Wires
Triple Sandwiched Leads
Hand Crafted in
USA
USA
USA
USA
Fs
31.1 Hz
29.2 Hz
26.8 Hz
25.1 Hz
Qms
5.5
5.8
6.6
7.1
Qes
0.41
0.47
0.49
0.56
Qts
0.38
0.43
0.45
0.51
Mms
181 g
227g
268 g
357 g
Sd
310 cm^2
480 cm^2
810 cm^2
1210 cm^2
Vas
19.1 l
42.0 l
120.1 l
255.2 l
Bl
11.7 / 17.2 TM
11.7 / 17.2 TM
11.7 / 17.2 TM
11.7 / 17.2 TM
Spl
83.4 1W/1m
85.5 1W/1m
88.5 1W/1m
89.6 1W/1m
Xmax
21mm
21mm
21mm
21mm
Wattage
1250wRMS
1250wRMS
1250wRMS
1250wRMS
Displacement
0.12cuft
0.16cuft
0.19cuft
0.24cuft
10" ICON D1/D2
12" ICON D1/D2
15" ICON D1/D2
18" ICON D1/D2
Coil(s)
Terminals
Push terminals
Push terminals
Push terminals
Push terminals
Cone
Pulp Fiber Cone
Pulp Fiber Cone
Pulp Fiber Cone
Pulp Fiber Cone
Suspension
Motor
FEA optimized motor
FEA optimized motor
FEA optimized motor
FEA optimized motor
Former
Lead Wires
Hand Crafted in
USA
USA
USA
USA
Fs
31.1 Hz
29.2 Hz
26.8 Hz
25.1 Hz
Qms
5.5
5.8
6.6
7.1
Qes
0.41
0.47
0.49
0.56
Qts
0.38
0.43
0.45
0.51
Mms
181 g
227g
268 g
357 g
Sd
310 cm^2
480 cm^2
810 cm^2
1210 cm^2
Vas
19.1 l
42.0 l
120.1 l
255.2 l
Bl
11.7 / 17.2 TM
11.7 / 17.2 TM
11.7 / 17.2 TM
11.7 / 17.2 TM
Spl
83.4 1W/1m
85.5 1W/1m
88.5 1W/1m
89.6 1W/1m
Xmax
21mm
21mm
21mm
21mm
Wattage
1250wRMS
1250wRMS
1250wRMS
1250wRMS
Displacement
0.12cuft
0.16cuft
0.19cuft
0.24cuft
That is from the previous version.
Excellent choice on the SSA Evil's. :)
28
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
3K
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
Texas pipeliner_00
CarAudio.com Newbie
Texas pipeliner_00
denim
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
