Skar audio amp setting recommendations
  • 2
I recently bought a rp1500 mono amp and 12"evl sub. I was lookin for recommendations for amp settings on gain, subsonic, and lpf for optimal sound without exceeding my 1250 rms max on the sub.
box description, wiring etc. The box is going to make a huge difference on the subsonic as if its set to way below what the box is tuned to (if ported) the woofer will flap around not producing any bass and potentially damaging it. Gain is set by ear in an empty parking lot far away from people with the volume set to the maximum listening level youll ever turn it up to due to the bass knob not having a clipping indicator. lpf at around 120ish depending on where it sounds best. all it does is cut the frequencies at 12db per octave at whatever freq you set it at, so its kind of a preference thing. leave the 3 position switch all the way to the left
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
914
Id keep with the warranty return. Id look at getting a different more reliable amp, and maybe Sale the Skar.. Thats me though. Seems like a PITA...
I usually build my own enclosures and didn't have the time to make another box, just happened to have the dual 12" box laying around. I see a 3.5...
  • Locked
COMPLETED Skar Audio RP600.5
sorry been on bed rest due to back issues. Looking for max depth of 5.5” 2ohm load 350 watts 1ohm load 500 watts
Tony Trismegistus
Tony Trismegistus
youdoofus
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
