1991gmc 1500 singel cab build
  • 7
Mike Munoz
Ok guys started from scratch traded sum wax for they subs amp an box
subs are 12 L5 solo baric kicker dual 4 voice coils
Amp is Z400.4 z edition mosfet 4 channel .max 1600w its
As for the stereo I haven't bought one yet an am open to your suggestions
Box was in good shape but can't yous because it won't fit behind seat
I'm you zing 0 gage wire from battery to amp an 6 from frame to amp
so I kind of made my one to fit their wish I would of came her before I started!! It's1/4 in plywood on front 1/2 in on the sides top an bottom reyenfoced with fiberglass mat/an cloth at all joints an seems yoused silicone on cut outs for wier sand /lacked /an painted the outside cause i have no carpit is this Guna work or should i start over
eny ways my question is how do I wier the 2 kiker to my amp an is it going to be Enoch power eny help would be grate thanks hers pix
Horysheet...this is def a mess. Including spelling. Red wire running from battery  pos to frame of vehicle ground?? That seems confusing. Also the sub enclosure made from furniture parts/pieces to make a box. Classic.
@shredder2 I know you've made a few angled sub boxes. Make this guy a design that will fit 1 or both subs. And a good laugh might end it!!
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
167
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
406
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
701
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
695
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
895
Mike Munoz
Mike Munoz
wew lad
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
