Need help identifying pin type in connector block
  • 2
clashcityrocker
Hi, I have a Kia Sportage, and bought a "complete" audio conversion kit that is less than complete.... :-(   There is USB, Analog and Microphone inputs on the connector block, but none of them are wired.  I really want to use the in-car services, and not drill holes for USB and hang in ugly aftermarket microphones.
I have found the pin-out, and I know I need to put my mic 3.5mm jack wired onto pins 10 and 22, I just need to source some of the small pins.   However I don't know what they are called, or where to source (in the UK).
Thanks for any help.
Hyundai Genesis coupe car stereo wiring diagram harness connector pinout 3.jpg
if you de-pin one of the wires and see how it's configured that will help your search.
places like Digikey, Mouser, and Newark should sell pins, but it will be a tedious search.  Good luck!
Run man... Run!! 💩 💩 👀 👀 :LOL:
976
That's an older sub, pretty sure it was made by Targa and its the Venom line. I remember seeing them back in the late 90's early 2000's if memory...
376
554
clashcityrocker
clashcityrocker
keep_hope_alive
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
