2014 silverado dual sa 10s
Maybe up fire, I did a 2 " lift to fit 2 F8L's forward fire. But I only have 10" height on the face of the box.
Here's pictures of the 2" lift I built, and of the 2 8 box. Port out the driver side with a storage area.
Honestly SA 10s want more space. I had two SA 10s in 3cubes and it was ok(made some bass) now I have two SA 10s in a huge box like 5cubes each and they straight hammer everything. Plays down to about 24hz.
U wanna stick to 6.5” and 8” woofers for under seat stuff forsure. Some massive audio 6.5” hammer for the price. Or sundown E 8” is a nice woofer for the money. Sundown SA 8” if u don’t mind spending the money
I have a box i built already for my 2010 supercrew i just got rid of, front firing about 3.1cubes
I believe there is some difference between years, the 14+ have less height and less trans hump. However just measure and see, it might work but you'll be lifting more than 2 inches. Be careful how much over 2" you go or the hooks wont grab the back wall.
Was trying to find out if anyone has built a proper size box under the rear seat for dual sa10s
The 3.1 cubes shouldn't be too hard gross, but 3.1 cubes net with proper port area is going to be a challenge. I think without my storage area I'm close to 2 cubes net with 22 sq in of port area.
You will have 2 more inches of height, and I didnt build my box the full space under the seat, theres still about 3 inches of width left.
Hope you dont mind me bumpin this.. but I want to know if there is enough room for a single SA-10 in a ported box under a 2010 crew cab? I currently have 2 DC audio 8's in a ported box. They nice but I'm looking to get a bit deeper with a SQ finish. Am I off my rocker thinking a single 10 will be lower and cleaner than 2 8's? Anyone wanna build me a box? I got money lol
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
962
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
655
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
978
apeterson26
Memphis, tn
Infamous☆M☆PTB
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
