Kenwood dmx905s won't control Spotify through Bluetooth
  • 2
yes it works when on android auto through usb. It has a spotify app you open when not on android auto but it says  disconnected even though the bluetooth is hooked up
go into your phone settings and forget the deck in your known connected bluetooth devices, repair and see if that helps. ive found that some things dont work the same over BT as it does over USB on my pioneer deck too. Seems like a limitation based on the model. I found out that many higher end decks will do virtually everything over BT that my deck is limited to doing over USB such as nav mapping and so forth
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
462
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
Ppreedom
Ppreedom
youdoofus
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
