Intense buzzing when ignition turned to "on"
  • 2
  • Participants list
gmpisawresome
I just bought a Kenwood 9903s and have it wired up and working. However, there is hissing in the accessory ignition position and a lot of very noticeable buzzing when turned to the on position. I have grounded the radio to both the stock harness and the chassis. Interesting thing is I hear a relay switch when going from on to acc, and the intense hissing immediately stops once you that relay switches. I have the jbl premium sound system in this Toyota Celica, so I have 4 rcas coming out if the harness and into my radio. What should I do?
did the old stock deck have rca's going out of it too? might be providing the stock amp too much voltage
Sorry for such a late response. I am almost positive that it was that because after bypassing the amp, it was much quieter. Thank you for your help, now I can listen to clean music!
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
“ I would try using shielded RCA wires for starters, see what happens.” I think I’m going to start off with that
929
gmpisawresome
gmpisawresome
lakeland fl
youdoofus
Doxquzme
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
Latest topics
