Noob question regarding box size
sypherian
So basically the title says it all.
I'm about to order a pre build sub box and since they only come is some pre defined sizes I have some questions regarding this. And before someone says anything about building one I'm an IT guy i can set up a complete company server environment, build a whole Virtaul machine environment with all the redundancy ever needed and configure network until your hearts content but I cannot work with tools larger that a screwdriver so cutting gluing and hammering a couple of MDF boards together is not an option atleast not for me to be satisfied with the outcome that is (some mild exaggeration might have been used)
I can get a closed box that fits the sub perfectly according to manufacture specs but I'm having trouble finding a ported box with correct size according to manufacturer specs that is so my question is how will a box too small affect the sub and how will a somewhat larger box affect it.
Kind regards
Sypherian
Kind regards
Sypherian
there are many box builders on the facebooks who can build you whatever you need for reasonable prices.
get a hold of Shaun at NorthWest Audio Suppliers...he just built me a custom box for a very very reasonable price.... shaun@nwaudiosuppliers.com
I probably should have mentioned this in my post I'm situated in Denmark so ordering one from him in Oregon will probably be the most expensive sub box seen in a long time with transportation and customs charges :p
Maybe I should just contact a carpenter if I bring a case of beer and some MDF for him to cut out I might end up getting it reasonably cheap.
I probably should have mentioned this in my post I'm situated in Denmark so ordering one from him in Oregon will probably be the most expensive sub box seen in a long time with transportation and customs charges 😛
nah, have them put some of "oregons finest oregano" in the box and make the shipping worth your while. Customs might indeed take issue with it tho. @shredder2 can you take a moment to stop fighting the shelled pizza-eating reptiles to get something whipped up for this fella so he and his carpenter can put something together?
@sypherian list your model of sub and size requirements for the box like how much height depth and width you can allot to the box and im sure shredder can hook you up
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
sypherian
sypherian
sypherian
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
