Car audio suddenly has issues
  • 5
  • Participants list
JoeZ
Tampa
Hey all, I'm sort of at a loss right now for fixing my car audio setup.  This was all working fine for years, but suddenly got really distorted, then died all together.
I have a sub in the back, with audio coming from a Sub line out on the HU.  This is working fine.  I'm using Front Line Out on HU to a 4 channel amp (only using front channel).  This feeds into L and R filter for tweeters and speakers.  I'm getting no audio out of the 4 channel amp all of a sudden.  When I hook the sub into the Front Line Out, I can hear the sub working.  If I bypass the amp and filters, hooking the speakers into the SPEAKER OUT, then I have audio.  I checked for continuity on the lines, all good.  I bypassed the filters...still nothing.  I replaced the amp...still nothing.  Power light on amp is on when radio is turned on.
Is there anything I could be missing here?
Clarify you are using filter to refer to a passive crossover that divides the audio signal to tweeters and woofers in a component system.
Clarify that this sentence:
Means you connected the head unit speaker outputs to the speakers and have music.  Is this with the crossovers (i.e. filters) or without?  Do the speakers work on the head unit with the crossovers (filters)?
Picture of the 4ch amp connections?
Thanks so much everyone for the thoughts--I'll check all those things and report back.
73
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
What he's saying is you need to pull the head unit out of the dash. Leave it connected to play, pull the speakers out of the door, and the wire...
708
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
JoeZ
JoeZ
Tampa
Haunz
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
