How to get just the sub out of the stereo. Sony DSX-A60BT
  • 3
thedjplutonic
CarAudio.com Newbie
Hi all.
I've recently bought a new sub that I've linked to my stereo. I have an issue that the stereo Sony DSX-A60BT only has 2 x 2 rca connections,  the front and rear, nothing else. I have gone through all the settings on the stereo and nothing. Is another stereo needed with an actual sub out output? Any help appreciated . Cheers for reading.
 tossers and wankers.
Oh ... that IS English... I digress
Here is a great little item that will do the bull work of what you want to do. The nice thing is that it doesn’t require a separate remote turn...
4
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
I dont know if this is supposed to be posted in here So pretty weird question but does anyone know is it possible to connect a car stereo into a...
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
thedjplutonic
CarAudio.com Newbie
thedjplutonic
thedjplutonic
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
