Upgrading Honda Accord 2015 LX Base Model sound system
  • 2
Acide24
15
Georgia
Just got an accord 2015 LX and well the sound system blows. Read about some people changing dsp flat to on through the developer menu but that was for different trims. Anyone know if this works for the LX? Is there anything else I can do to improve the quality? I would like to keep the factory head unit because of the ability to use the iMid (rear view camera screen, gas mpg and range screen). If there is a way to keep all the functions and the iMid screen, I would upgrade my head unit. I know that upgrading the head unit alone to something that has an eq, lpf, hpf, etc will do wonders. I just would like to keep all functionalities. I read that you could bury the factory head unit behind climate control and install a new head unit and keep all functionality. This seems extremely complicated and might not be worth it for me. I've also read about disabling the ANC module. Will this improve sound even if everything is stock? This seems to be a solution for people who have added a sub.
Simple solution leave the head unit alone. Get a dayton DSP and Bluetooth dongle.
So have your head unit connected to the rear speakers only for calls. But other than that everything on your head unit stays completely stock and untouched.
Get a dayton dsp and usb dongle and do an audio system for your front stage and subwoofer that completely bypasses the head unit. All audio will be through Bluetooth straight to the DSP. The audio is actually very clean. Youll will have 8 channels of audio output Available for use, all the audiotuning capability surpassing the best head units out there.  All under 200 bucks.
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
441
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
9
727
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
When I stripped my factory system and started from scratch. I didn't need any adapters. I wired the new head unit wiring harness to the vehicle...
8
770
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
8
Acide24
Acide24
Georgia
Jeffdachef
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
