Ok update I picked up a lc7i converter and have it in the rear by my amp. I tapped into the speaker wires at the b pillars by the sill plate. It sounds good for the time being. Black Friday shopping yielded me a alpine 4 ch amp. Question for you Chevy/gmc crew cab owners who has pics of amp racks. Looking for ideas. And still searching for front speakers and rear door speakers.
What most ppl seem to do (myself included) is to fabricate an amp rack (plywood, MDF, abs, etc) anywhere from 1/4"-1/2" thick and mount it to the trucks rear wall.
Theres not too many options when it comes to mounting amps in trucks, but the rear wall is actually perfect and gives u decent amount of space & options. For those who like stealth you can keep them hidden or if you like to show your install off you can do that too.
If you do a Google image search for truck amp rack there should be enough pictures to give you some ideas...
The most important thing when doing an amp rack like this is planning, make sure to double, triple check your measurements, I suggest making a test piece out of cardboard so you're able to pre test your fitment. Also make sure you take into account any obstructions like sets belts, hinges, anything that could potentially cause your rack not to fit properly when installed, make sure everything will have enough clearance with the seats back down. Also good idea to mount your amps so if you need to make any adjustments on them they can be easily accessible. Basically just take your time and plan plan plan, lol.
Heres mine, the 1st picture is my current rack after I got a new box and was able to move some things under the seats. Put a piece of black abs over the wood, was planning how the wires were going to run... The rest of the pictures are my 1st version that was spray painted black plywood and had all my amps/components on it at the time.
