Fuse question....dont kill me lol
FineLinePimpin
Stuck in WV
So im trying to configure what size external fuse I'll need for my new wiring as my Scendo doesnt have internal fuses...
is Amp wattage x 13.8 + 20-30 = xxx  , which I saw on youtube, still a good/decent estimation?
so basically it would be 2250w rms  x  13.8 = 166.67 + 30 = 196.67 so I should have a 200amp fuse?
Sorry guys...lol..thank in advance
 Crescendo BC2000D and going for 1/0ga and doing a Big 3. 2003 Tahoe stock 135amp Alt for now but will be going with a big quality battery.
You should be just fine with a 250-300/amp ANL fuse at the battery with the 0ga wiring and follow up with proper fusing like a distro block at the amp/amps for fusing.Should be approx 20-25ft run of wiring for that vehicle, that alt should be plenty with the Big 3 in 0ga, and a decent Group 34/78 AGM battery for that amplifier, and a decent 75-100x4 mids and highs amplifier with a good ground
Thanks dude. I do have the bose system and wanted some mild updates for the doors which is why I went with the simple pioneer 3 ways for each door I was doing to run off the head unit.
It should sound a little better than stock.I hope it all turns out well.You have plenty of room in that vehicle to do whatever youd like.I recommend to deaden the front doors if you have the time and funds.Its worth it.
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
577
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
FineLinePimpin
Stuck in WV
FineLinePimpin
Bunker Hill, WV
FineLinePimpin
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
