Jump to content
Joel114
Can I just use thhn electrical wire for an amp?
Recommended Posts
I work as an electrician and have enough 4 awg copper thhn stranded electrical wire to run from my battery to the amp I am going to install. Could I just use that instead of buying some EB Flex? Is there any downsides?
Share this post
Link to post
Share on other sites
Yes, that will be fine. Only downside is that it won't be as flexible.
Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
Share this post
Link to post
Never any down sides about going with a bigger gauge wire. If anything, it has the potential for better performance. A well fed amp, is a good amp. I don't know if the 4 gauge you're going with is an upgrade from a smaller gauge, but if so, remember to give it the right fuse. The kind of gauge you use usually determines what size fuse you need. Good luck.
Share this post
Link to post
Good job completely missing the question^^^^
2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
2010 Focus coupe 157@46hz
Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
https://www.youtube.com/popwarhomie
too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
Share this post
Link to post
We can safely assume you know how to use ampacity chart and #4 is adequate for your amp(s).  The main difference in "car audio" power cable is flexibility and sometimes better/thicker insulation.   Just be mindful about putting wire anyplace where it might flex or rub on something, otherwise, copper is copper and electrons really don't know the difference.
Share this post
Link to post
If you live in a cold climate, you will want the more flexible wiring. Getting thhn to flex when its cold is like trying to bend the branch of an oak tree.
Share this post
Link to post
Yes It'll work just fine
Bought from: tc3k101, vitveet, chico305, pieper88, Toxic Tuan, rusty_armadillo, tristanmay
Traded with: modskwod, jmkanek
Sold to: smd4life, AQHDC3, fastfocus00
Share this post
Link to post
I've used zero gauge thhn in several cars and I've never had a problem. Just have to be a little more creative with the routing.
Share this post
Link to post
With car audio where there is DC power instead of AC compared to the house,  the current tends to loose over distances from the car battery to the back of the trunk area.  Simple way to know your power requirements is to add up your amplifiers fuse rating and add 10% ( due to loss) and then go shopping for the appropriate wiring kit.  In most every day driving 4 gauge or 2 gauge is sufficient unless you plan to enter the SPL lanes then back to the drawing board for you!:cool:
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
