Car amp inside house, Ground?
  • 5
Hey,
i have a system in my car that i have to take out, ive allways wanted to test it in my room, but how do i ground the amp/batteries?
i have two 120ah batteries and a 2.5k amp powering two hdc4-15s, i wont be using any alt/distrubitor just the batteries (worked fine in the car) (yes no alt, voltage drop fine just 0.3 max) but there i had the intire car as a ground,
**so, are the negative terminals on the batteries good enough ground?**
i really appreciate any input from you guys:)
yes, just battery positive and negative terminals are needed.
you need fuses, obviously, so you don't set your house on fire if a short happens.
you also need a way to charge the batteries, so a battery charger is needed at some point but not for short testing.
Another alternative is you can purchase a AC/DC converter from an electronic shops.  You can get up to 40amps and that is more than enough juice to get loud in the house since the speakers are directly in front of you and so is a subwoofer if you happen to have one lying around that you can use.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
733
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
5
934
Now you want to know how to do this on your own car? On certain cars that allows you to use head units that are high power, you'll be bridging...
8
Bazzheadnorway
Norway, Oslo
n2audio
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
