Using an RTA program to measure and manually fix factory radio EQ
  • 1
keep_hope_alive
Premium Member
Acoustics Engineer
There are several options to fixing the stock sound systems and getting bass back.  I've been using the JL Audio VX1000/5i for over a year (since August 2017) and i've used the preouts to fix the factory EQ.  I finally made a video detailing the process. This method allows you to use an EQ and see what you're doing to correct for the response.   Other videos describe using RTA software to see the audio signal in more detail.
https://www.youtube.com/watch?v=lmHCnhsvfGo
Hit me up with any questions.
557
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
453
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
936
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
961
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
