4ch down to 2ch bridged?
ThxOne
Premium Member
The Boss
If you bridge a 4 channel amp down to two channels... will it still be stereo?? It would be using a stereo 2 channel input. The goal is to have it be a stereo signal. Would I need Y adapters for the RCA inputs?
I am wanting to use 3 amplifiers powering 2 tweeters, 2 small mids, 2 midwoofers, 1 subwoofer. Amps - US Acoustics - 4ch Barbara Ann (tweets and small mids), 4ch Lisa (this one bridged to 2 channels to power midwoofers) and 1ch Mike (subwoofer).
I am asking because I don't know how amplifiers go about bridging. I know it will take a left and right (stereo) signal and sum it to mono. But what is it inside the amp after it is bridged?? Is the whole amp now mono or is there a stereo signal comprised of the two mono channels?????
yes, you can bridge and retain stereo.
A lot of amps have a 2/4 ch input switch, but I don't see that option with that amp.
So use y cables for your l/r signal cables.  Lefts into ch 1/2, right/s 3/4 which gives you L bridged on ch 1/2 and R bridged on 3/4.
Thank you... my brain was leaning that way. My worry was is the amp split internally... 2 channels on one side and two on the other. Thanks again.
I actually bought my Barbara Ann from SSA when it was under $200. This amp is a beast. Clean and loud for sure and has NEVER got hot on me, has never shut down.
That is awesome to hear, thank you.  The Lisa has been a strong choice for a number of people wanting great power for the dollar in a 2 channel.  (bridging it of course).
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
511
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
736
Cool down, bro. and have a happy thanksgiving. I was merely inquiring in response to someone else's post that cautioned about clicking on the...
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
denim
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
