SQ/wiring question on budget speaker replacement
1995Tercel
35
SW Utah
I have a 2000 Honda Insight, with four factory speaker locations. (rear, behind the seat speakers were a factory or aftermarket add on)
It has a pioneer deh-x9600bhs head unit, polk db651 6.5" door speakers, and I'm about to install Earthquake Sound SWS-6.5X shallow mount "subwoofers" in the rear speaker locations. There is very low clearance on the pass side, since the fuel filler neck is 2" behind that speaker location, so I thought I'd try the shallow mount.
My question is.. since the "subs" are very small, do they still benefit (overall sound quality wise) from being wired into the head unit as a subwoofer, and having a dedicated frequency range? Or do I just wire them into the headunit as normal speakers?
Thank you for your input.
It is most likely a waste of time putting those subs back there unless you built enclosures for them or completely seal the baffle for an IB set up.. Headunit power would not be anywhere near sufficient.
Watch the video pop put up. Those don't put up anywhere near what they claim. Hence why spokey said run it at 1 ohm.
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
Or a 25 and a 30, 25s are just harder to find in stores. I may be able to get one from my local audio installer. I already have to talk to them to...
1995Tercel
1995Tercel
SW Utah
n2audio
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
