"Junk in Her Trunk" VW R32
  • 5
Do you have a CNC machine or did you do that all by hand?   How many sheets of wood did you burn up?
All done manually on a table router.
(2) 3/4" sheets
(2) 1/2" sheets
(1) 1/4" sheet
I'm also making templates of all the pieces so I can do my R32 next
Fab work done. Magnets installed on forward and rear edges of trim panels instead of visible hardware. Handing off to the owner's boyfriend for the air tanks, hard lines, and upholstery then back to me for the rgb led lighting for the subs, air management, and the acrylic window which will be laser etched.
IMG_6092 by Jon Polo, on Flickr
IMG_6093 by Jon Polo, on Flickr
IMG_6157 by Jon Polo, on Flickr
IMG_6158 by Jon Polo, on Flickr
IMG_6230 by Jon Polo, on Flickr
IMG_6193 by Jon Polo, on Flickr
IMG_6195 by Jon Polo, on Flickr
IMG_6192 by Jon Polo, on Flickr
IMG_6199 by Jon Polo, on Flickr
IMG_6238 by Jon Polo, on Flickr
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
660
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
968
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
crnacnac
crnacnac
Pasadena,CA
crnacnac
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
