DirtyDuzit
Haven't had these long and just recently decided to check the impedence of the lead going into the amp
I saw 1ohm I have two so in expected much closer to .5, thinking one was disconnected I cut into the back of my box (4th order with no removable panel) all the connections were perfect so I checked the impedence of all the coils. Then the impedence of two coils then again the final load.
2.5-2.6 per coil.
1.4 with two coils
1.0 with all four coils.
Is my wire adding impedence? It's 10 gauge OFC I got from some Monster cable I found. I do have about 12ft of it coming off the box at the end which can be shortened.
2.5-2.6 per coil.
1.4 with two coils
