john_doe_318 10+ year member
Hello i have a sq hds3.12 and sq 1250 gain at like 40% lpf at 40 and subsonic at around 40 all 0 gauge wire big 3 (knu bassik cca)box is small 1.1 cu ft box at about 40 hz prefab. I jus upgraded to the sq amp from a 500 watt db drive was decent. Question is i had no clipping with the db and now my sub clips idk y. I was thinking box was to small or the cheap cca wire or voltage it stays above 13 this is in 06 trailblazer any help os appreciated
