2 ct sounds meso 8s vs 4 skar ma 8s
Rroark90
Having a hard time deciding on subs for my 2015 extended cab Chevy wanting the loudest I can get for my budget which is around 500 bucks for the subwoofers going to run 1500-2000 watts stuck between 4 skar ma8s and 2 meso 8s also open to alternatives
I really like the sa and the x but a little out of my price range I don’t have much space it’s going under the seat in a extended cab even with the 8s I’ll have to lift the seat 2 inches
So should I do 4 vfl or 4 soundqbed or 2 fl8 or 2 sa I haven’t heard any of these subs in person I live in Wichita KS we just now got a new shop selling sundown and dd but all the prices are marked up
The 4 8s will be louder the Tropo 8s claim higher RMS for less price but didn't check the actual specs
I love CT and Skar I think it's great thing when we have these smaller companies bringing budget products to the world.
I run 2 Tropo 18s on a skar RP2k @ half ohm. The subs take it no problem but it hasn't been very long so that with a grain of salt.
Skar has some cool 6.5s $59.99 each 2 inch coil.
If you can spend $500 just get two SA-8s.
The trick is going to be airspace to go ported... myself, I'm planning on 2 F8L's on a 2k in 1.5 cubes ported tuned to 33hz. But mine is a crew cab. 18 crew cab sierra. But even with a 2" lift, I dont think I can fit 4 8s with proper airspace and port area. I can fit 3 8's though.
The formula is Square Root of your target Wattage Multiplied by Ohms. 50Wx4Ohms=200. Square root of 200 is 14.14. So 15v AC is your target.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
536
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
Rroark90
Rroark90
Wichita,KS
denim
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
