Boston Acoustics Speakers Parameters
  • 2
Zoltan
Hi Everyone,
I have a few speakers lying around and I was thinking (foolishly) that I should do something with it like build a set of home loudspeakers
I have already found PDF documentations online, the "ProSeriesCompMan.pdf", "Pro65LF.pdf", "Neo5Tech.pdf" and I also already contacted the support on the Boston Acoustics site but they said that they don't have any archive and directed me to third party a documentation website that I already had, so I guess that since it had been bought by Sound United they don't care anymore.
So I hope to find more details about the parameters/specifications, like Thiele & Small & Crossover parameters on the following speakers :
  • ProSeries 5.5LF
    I have the full kit including the Neo5T below and the crossovers boxes
[*]ProSeries 6.5LF
  • Just the pair of woofers
[*]Proseries Neo 5T
hoping that i don't have to spend money into a "DATS V2 Dayton Audio Test System" to get that information that may not be very accurate anyway.
I was thinking about maybe making a three way system but unsure about the usefulness of having the 5.5 & 6.5 together, not even sure if the whole think would sound good in a home situation in the end.
Thanks
Zoltan
View attachment Neo5Tech.pdf
View attachment Pro65LF.pdf
View attachment ProSeriesCompMan.pdf
If you are that concerned about parameters for those speakers you will need to measure them with the DATS equipment and invest in Bass Box Pro if you are trying to build an enclosure for them and use them in home theatre.
Thanks for your reply THATpurpleKuSH,
I was hoping somebody else has already done it, I could indeed go with DATS and then sell it back after or approximate it, after all not all door compartments have the same volume small deviation would not hurt that much the sound, playing with more or less damping for tuning
Ho it's not for a theater but stereo setup
I must be sentimentally attached to them they have done such an excellent job in the car I had years back, it's difficult for me to sell them.
Best of luck on the search of these Gems 👀 👀 💩
Massive doesn't provide much technical detail on the CT2, but looking at the response curve suggests an FS of ~1.4khz and the listed frequency...
15
231
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Zoltan
Zoltan
Zoltan
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
