Questions About Installing Speakers in Car
Joel114
CarAudio.com Recruit
67
I plan on buying this kit to replace my factory speakers in my 2005 pontiac sunfire (it is pretty much a chevy cavalier). It is a coupe with a woofer and tweeter on each door, and two woofers above the trunk? Would I be able to use my stock radio and wiring for them? Would I need an amp to power them? Do I need anything else besides the kit and maybe some crimps?
You'll want an amp. Technically you could use your stock head unit but they will be severely underpowered and will not sound good at all.
These are the speaker models (6.5+6x9) sort of just newer, what would you recommend for an amp?
I would avoid 3 ways as they are mostly garbage unless you get to some real high end ones. For your budget I would recommend using all the money on the front stage.You get a much better return on money spent.
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
280
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Thanks for the reply bass addict. I am sure with ya'lls help I'll get it tuned up. Audiobaun has been a huge help. He basically linked everything...
50
5K
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
973
It's really hard, almost impossible to induct noise into RCAs. All you need is a simple set of shielded RCAs. Some home audio guys once did a...
19
Joel114
Joel114
ckeeler11
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
