Static through my system.
  • 2
s0nl33t
7
Canada
I've only had my system in my vehicle since May of this year. A few days ago I happened to notice some static through my speakers. This is the first time I've heard it. It seems to be coming through all four speakers that I have wired into my amp. Front and rear. This was not like this before.
I had a track playing through my bluetooth in my vehicle the other day and during the track the amps protection light came on. It stayed on for less than 15 seconds with no sound then went back to playing normally. Could this have damaged my amp and caused it to start producing static? If not this,  what else could be producing the static?
Id check each speaker with a DMM and see if they are blown or not from clipping..you can view a You tube tutorial on how to use a DMM/Digital Multi- Meter to check Ohm load on a speaker or sub, or tweet.Id start there
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
859
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
s0nl33t
s0nl33t
Canada
audiobaun
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
