Speaker Popping
  • 4
Check your settings on amp and HU. Its possible you may be clipping your speakers is what it sounds like to me..I like Jeremy11 question as well.May need to make some adjustments before you damage your speakers
My settings on my HU are all at normal nothing changed with the HPF or LPF. My amp is just set for normal frequencies no bass boost or anything. I have my gain lower then the normal and the front speakers start popping at 4/5 max volume.
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
704
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
729
You could do the 8" as a front sub on its own amp and use it to bridge/enhance the gap between your 12" in the rear to the midranges
6
550
ElectricSoap
ElectricSoap
Odenton, MD
ElectricSoap
1aespinoza
    Apr 17, 2024
HandsomeSteve
    Apr 16, 2024
Latest topics
