do i need good speakers for a sub?
jflynn
im thinking of getting a set of subs to put in my truck. im still new to this stuff, just wondering if putting in 2 12's in with not so great speakers would sound bad or good? i dont need the loudest or deepest bass i just want some more bass, not really trying to get loud ass music. i got some cheapish kenwood speakers and put them in a while back, they sound good at a decent level but if they get too high they're raspy, but i don't even really want my music that loud. will adding subs just add more bass and not make my speakers worse?
With what you're describing you have no need at all for a pair of 12's.  One decent 10 would probably be enough to drown out your full range speakers at high volume.
The only reason im getting 2 12's is cause my friend is getting rid of his, he's selling them to me for practically nothing with everything included.
well, in that case, sure.  Just keep the gain down, probably set the low pass pretty low too, they'll sound fine.
An amp to support your front speakers would help things blend better -- also would give you a high pass filter to cut the lows, which is what causes the majority of the distortion in full range speakers.
X2 @Jeffdachef
to piggyback on Jeff's comment, you might want to keep stock stereo and speakers as most stock speakers work best with OEM stereo. Just add sub amp to OEM HU. Just an idea since you don't plan to get crazy loud.
I would buy your friends stuff and sell them. If you are not trying to get loud, I would get a sundown shallowmount. Use the money to fund a sub and custom box. You keep space with a custom box and can maximize on sub sound. Sundown's shallow mount sound pretty damn good imo (had one in my frontier). If you are in SoCal, I might have a SD10 sub laying around if interested.
It depends what rms the 2 12's are if your thinking of 1000watt rms subs then good rule of thumb is 100watts speakers for every 1000watts rms subs. So if they are 500 watt rms then 50 watt speakers should do fine. Upgrading to a good aftermarket headunit that puts out 30-50 rms per channel should bring new life to your factory speakers and make everything  sound pretty uniform.
:wow:
sooo, which HU's offer that kind of power?
None do. Not realistically. You can buy the boost pack mini amps that can fit in the dash though.
Really for what you want a simple sub, amp, box should suffice.
Dont go too cheap on the hi/lo converter. The cheap ones often fail. But you dont need a $200 either
Hello, Last year i installed in my mom's car (Mercedes A140 W168) an aftermarket head unit (Pioneer DEH-S320BT 50*4watt) and also changed the...
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
Yes, one shop is absolute best and last time they let me return it even when i mounted it on the car and tried it :)
jflynn
jflynn
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
