Broken 125.4 AMP
  • 1
West1
//content.invisioncic.com/y282845/monthly_2018_09/amp.jpg.8fe5810754b21ca94d81cbbcebcfb5fb.jpg
View Advert
Broken 125.4 AMP
I've had this amp in my closet for about 8 months. Used it for about 1year.
During the time I had it, the solder at the RCA came lose and I redid it myself. it worked fine for about a year then purchased a new amp. I am no electrician but I believe this is the issue. If you can resolder CH1&2, I believe all 4 ch's will sound properly.
Because I am not 100% positive... 50.00 takes it!
Will not ship, Local pickup only near 90245 or 90220.
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
West1
West1
Los Angeles,Ca
West1
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
