Dont quote me on this one. Of course i would check the connections. But i've seen this happen befoe and i swore it was because of trying to pull too much current through the power wire with too small(guage )
Thats a possibility as well, but that fuse should blow if it gets too hot, before the casing of the wiring is burned offDont quote me on this one. Of course i would check the connections. But i've seen this happen befoe and i swore it was because of trying to pull too much current through the power wire with too small(guage )
STFU... Jesus ******* christ no one cares. You try to turn every post about you.can't believe mine never has wire and fuse block 14 yrs old.. i have new one to install soon because of this
Depends on your current draw.New fuse distribution block with ANL fuses came in and already installed. Currently using 8 guage wire, do you guys think I need to change it to 4 gauge. Those wires go to 2 amps. 4 gauge wire from the battery go into this distribution block and split into two 8 guage to two amps.
Thank you,
