Kenwood DDX795 question
Polar
Question about a Kenwood Excelon DDX795. What would cause zero increase in volume from say, 25 on the dial and upwards( maybe I am finally going deaf?) No noticeable volume increase and it seems to " roll off" the bass. In the eq it has a few setting, many which I dont understand. For instance, bass extension and drive eq. I have an email into them and the manual does not explain very well. Thanks!
turn off all eq enhancement settings. it sounds like you have a loudness setting turned on. What is the max volume number just to put the 25 number in relation to something
Polar said:
40 is the max, there is like zero volume increase from 27 all the way to 40
I had a similar issue with my eXcelon. My EQ is a 13 band, each band is -9 to +9db. All of my bands were ABOVE 0db. Set your EQ bands BELOW and only UP TO 0db. See if this helps... it helped me.
134
So I checked the ground wire. And god*am*tt, the frekin ground wire had wiggled out of the connector. Put a new connector on and everything works...
19
447
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
509
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Polar
Polar
WPB, Florida
ThxOne
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
