Advise needed on port tuning
  • 2
Boost_luke
CarAudio.com Newbie
Hi guys. New to the forum. I’m just building my first decent install. I have built a box but I’m stuck on the port length. The box outer dimensions are 36wx13hx13.5d outside using 18mm 3/4” mdf. The box internal volume is 2.7cu without the port. Port opening is 3”x 308mm but I’m stuck on how long I need to port to be. My sub is a bassface spl12.2 and has a recommended 2.5cu with a port tuned to 35hz. Any help would be greatly appreciated
3 inches is to small of a port for a 12 inch sub, you should use a 4-6 inch port or else you will have a ton of port noise and compression. With a 4 inch round port you would need a length of about 7.5 inches or 19 inches with a 6 inch port.
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
337
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
Boost_luke
CarAudio.com Newbie
Boost_luke
THATpurpleKUSH
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
