Both of my Mono and 4 channel amplifiers have no power but they both worked perfectly fine the day before. I have checked continuity on all the ground wires and they are good. The REM wire for both amps have voltage and the power cables have power (only) if there not connected to the amps. When its just the power cord, I get around 11 voltage, as soon as I connect the power cords from the three way distributor block into the amps, I get .3 voltage. All the fuses are perfectly fine as well. I have no idea what the problem would be. If anyone has any ideas, im totally open for suggestions.
Thank you.
Thank you.
