Need help on replacement tweeters for older Focal Utopia 165W & PolyKevlar 165K2p
  • 3
TexasThump
30
Enid, OK
Had to repost my question from a few weeks ago. Accidentally pasted a paragraph I had typed for my TitanTalk forum thread.
So, I decided not to install my BNIB JVC KW-NT800HDT, yet. May install it in another vehicle or sell it. Already have the exact same one installed in my 2018 Calloway Camaro ZL1 1LE SC750 & absolutely LOVE it. So I bought the all new JVC JW-V940BW audiophile Navigation/Multimedia/Touchscreen
It's been a costly learning curve trying to figure out this whole iDataLink integration with the Maestro RR, ALDS, keyless start RFID Module, T-Harnesses for the JVC & for my new viper 7906V way LCD Alarm. Apparently the THR-NI3 & THR-NI4 T-Harnesses & the Maestro SW aren't applicable for my install. 20 years of installing car audio, step away for a few years & I misunderstood the whole iDataLink thing. Lack of product description & lack of wiring installation diagrams for my Titan.
Anyway....
I seem to only have a pair of TN51 tweeters, but one is missing both positive & negative wires with no leads coming from the voicecoil, one PolyKevlar tweeter, one PS165 tweeter & one cheap Digital Designs Entry Level Tweeter. No pairs I can use. Ugh.
So since I just dropped $11k on my truck, I need 2 pairs of tweeters that sounds just as good if not better than original TN51 & TNK Tweeters, but affordable & preferably can handle some power. I will be using the passive Focal crossovers my components came with. Replacement pairs are $400 & $600+ & Focal's only weakness is their recycled Tweeter designs so they haven't changed over the years.
I need to not be spend more than $400 total, but if it's worth it to stretch that, I'll consider it.
Thanks
Anyway....
Thanks
https://audiointensity.com/products/legatia-20mm-soft-dome-tweeter-specify-silver-of-black-pair
2 pair would be 530, but very likely worth it once installed and properly calibrated
Hey everyone! I recently bough a replacement "infotainment" radio for my mazda cx-5 as the default one is pretty bad. My problem is im having...
11
375
554
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
834
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
TexasThump
TexasThump
Enid, OK
Matthew S. Turn
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
