Amp power polarity reversed
  • 2
  • Participants list
BreadLord
17
Gaffney
A Hifonics BXX3000.1D was hooked up, but the polarity was reversed. The fuse blew and after being replaced the amp powered up and played fine. Is there anyway that after this happened that the output could be reduced and it not be putting out what it should?
I can remember seeing another user on a forum who reversed his power polarity on another amp. It played fine, but he said it didn't put out like he expected.
You may okay. There's usually a sizeable diode near the power inputs that can prevent huge amounts of damage resulting from reverse polarity. I think it either works or it doesn't after you've hooked it up incorrectly.
That's what I'm hoping for. I hooked it up fast in low light. Never again.
I also never could smell anything burnt and never saw any smoke at all. The amp still smells like new plastic at the vents.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
Hopefully it is ok to post a "for sale" ad on here. If not, I apologize in advance. Fully serviced Earthquake PHD2 amp for sale. Asking $175...
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
BreadLord
BreadLord
Gaffney
BreadLord
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
Latest topics
