Door Deadening / 'First Gen CTS
  • 4
cas0586
WV
Any tips/suggestions on how to go about deadening these door panels? Ive seen  lots of videos but none with these door control modules and ow to work around them. I will be using noico.
I used ABS plastic sheets screwed on top of those door parts so I could access later if need be and just siliconed to seal around them.Rest i Matted the entire doors and placed on back of inside door panel also, help deaden the door .I used a heat gun and rolled on to make a good adhere process.Just enough make it sticky not to melt.Approx 3-4 layers on my truck 2 layers on inside door panel. cut small sheets so easier to place and work with.You can find 1/8"-1/4" ABS sheets shipped off Ebay
Be sure to clean your doors pretty good before applying any Matt. Alcohol is cheap and works very well. Drys pretty quick also.
Tons of options in that budget, including the cost of installation,
10
519
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
363
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
8
cas0586
cas0586
WV
trumpet
Doxquzme
    Apr 13, 2024
1aespinoza
    Apr 13, 2024
Latest topics
