would a loose remote wire on amp cause amp to get hot
  • 5
redrobbin youtookbasicspellingandgrammer right
oneofthethingsthatmakesiteasierforustohelpyouisusinggoodsentencestructureandpunctuationsowecanfollowalongwithyourthougthsandquestions
youprobablyhaveshitwiredwrongwithalowresistanceloadandtheampisgoingintothermalprotect
regardlessfixyourlooseremotewire
thankyouforansweringyoucouldnthavebeenmorerightonwithhurtingmyfeeling
We tease a little bit here, just wanted to give you a little grief as a warm welcome to build the thickness of your proverbial skin. No real hurt intended, my apologies.
Do you think that could be it, though? Have you checked the final resistance with a multi-meter?  You may just need to reconfigure.
I used 3 awg power wire and 8 awg ground and 16 awg remote and 16 awg speaker
I got the amp without a remote screw and i use a wedge to hold the wire in till i get a new screw
Im going to fix the screw issue .
I was just curious if from the specs on the previous message bridged to the amp was not right for the amp
i dont know everything and i was just asking im trying to hook it up all by myself everybody i talk to here seems to think they are installers but when they look at it they dont do nothing but adjust the knobs on the amp or want to tell me about all the features and how to use them on my stereo
Good job doing it yourself, sometimes that's what you gotta do if you know everyone around you is full of beans.
First, you want to make sure your power and ground are the same awg. Go for 4 awg on both.
The screw you will fix but the wedge should be okay until then, you just want to make sure it's a tight fit and offering good continuity. Swap that out for the screw as soon as you can.
Finally, you may need to figure out a good blend of series parallel wiring to arrive at a safe final impedance that your amp is comfortable with seeing.
Where on earth did you find 3 gauge wire??? And never run 2 diff gauges to your amp. Always keep it the same.
What amp are we talking about here....since it wasn't asked? Fix the set screw issue.
Is it a mono amp? You might also want to consider a method of wiring that doesn't involve the amplfieir being bridged. Since your dealing with speakers that should be playing stereo signals and all.
im so sorry  if you go to a different question titled a girl needs help i asked yesterday it has all the info i forgot the specs were not in this question. another  question they want you to use huge wire for the amps but the part you connect it to  you can hardly if at all get the whole wire to fit in the hole
o be
o be
i got a package i got to put together that i sold on ebay and mail it it may be a minute before i answer back thank you for talking to me i have learned a lot from watching you tube videos and reading about ohms and running series and parallel but theirs still a lot i dont know and ill understand if it seems like it would be a lot to take on to help me . when i want to learn something ill seek it out on the internet instead of just sitting their saying i dont know how
Sometimes diagrams are the easiest way to understand the wiring thing. Just keep reading and teaching yourself, you will pick it up.
We'll all be here in the meantime.
did you see my other question i posted and yes diagrams really help alot
so basicly your saying to run the 4 six by nines one per channel would be the best for the amp or speakers or sound?
because when i did have them hooked that way the sound wasn't that loud than like when they are bridged but is having them bridged bad for the speakers?
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
920
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
yeah, it'll be hot but off. Just like your tv when it's plugged in.
robinredd
CarAudio.com Newbie
robinredd
Slo_Ride
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
