is dsp necessary
  • 4
ekah
hawaii
im running active on ppi900.4 on crescendo tweets and pwx in door and no rear speakers was wondering if i should get a dsp or if its a big different using the crossover points on my pioneer abh3700bhs on network mode.
Using a DSP will give you a lot more options for tuning each channel, so yes would make a difference. Now you are running Pro audio gear so is it worth it is another story.
you get more control with a DSP.  you get better crossover adjustment, more EQ channels, and more precise time alignment. If you want to have more adjustment, then yes, it is worth it.
if you just want the crossover flexibility, the Pioneer in network mode should do the trick.  What are you using for settings now?
Knobs😂 most dsp setups I've seen (granted they been cheap dsp) don't run the control knob from the amps so they can't adjust levels on the fly
11
130
For a tweeter, and you're on a budget, you can get bass blockers. It is not the best route, but they will work. Just make sure your installer...
8
156
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
321
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
ekah
ekah
hawaii
youdoofus
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
