Juat wondering what people's thoughts are on the fi omega. Ive emailed them a few times about the team v2 and found out they will be offering a 4th friendly version of the omega soon. Plan on running 4 18's on 4 taramps 8k's. Currently running 4 3 in coil subs on 2 taramps 8k's. The motor strength of my current subs is a little low as the gap is ment for an 8layer and in order for it to be a good forth sub i had to build with a 4 layer. The team subs have a lot more motor force and are 4th friendly but they recommend the cooling option for the power i planned to run. They said it slightly reduces motor strength that could result in a slightly reduced score but better for demos. I asked if the omega could be built for a 4th and they said it was already in the works. Should have more motor strength than the team and better cooling.
