lurice0
I have everything set at like 80 and i want to be more exact
My setup:
Up front is polk mm6502 (35-40k Hz) back is mm651 (40-25k Hz) all powered by Rockford p600-4.
Subs are 2 X-12 V.2 D4 - Sundown Audio (38.3 hz) powered by one of their 3000 amps.
My deck is a Kenwood DDX9903S 6.95" eXcelon Double-DIN that i hooked up to a Rockford 3sixty.3 dsp using low level rca cables. 3 sets of rca go from the dsp inputs to the head unit, 4 sets of rca cables go from the dsp outputs to the amps, so that i can also tune my separate front tweeters, however i really only have 6 channels?
Help me set HPF and LPF for front1 and front2, rear, and subs, based on my speakers specs?
I'm still saving for a quality RTA mic, meanwhile i just use the iPhone mic
My setup:
