First Audio Build - Looking for Recommendations
  • 3
Jacko-D22
Hi Guys,
So, i've recently purcahsed a new used car a 2012 Nissan Navara Dual Cab.
I'm looking to put together a first sound system for as budget price as possible, I'm currently looking for direction and to see if I am spending money in the right places.
As a total amount for the front speakers, amp, sub & headunit I'm looking at spending a max of $1,400 AUD.
I'm looking for input, suggestions and criticisms to get the best system possible for the best price, this is just a first build and I'm not looking at doing anything crazy with it.
So far this is what I've got together.
Headunit - https://frankiesautoelectrics.com.au/pioneer-avh-z5150bt-7-multimedia-player-w-apple-carplay-android-auto-bonus-rcamavic/#
Speakers (My car factory only has speakers in the front) - https://frankiesautoelectrics.com.au/polk-db6502-db-series-6-5-inch-2-way-component-speaker-system-300w-ip65/
Subwoofer (As the car is a ute, a slimline option is required - I will be building a custom mdf box) - https://frankiesautoelectrics.com.au/pioneer-ts-sw3002s4-30cm-shallow-mount-4-single-voice-coil-sub-1500w-max-400w-nominal-input/
Amplifier (To power front split speakers & subwoofer) - https://www.elite-electronics.com.au/In-Car_Entertainment/Amplifiers/Multi-Channel/Fusion_PF-8003D_3-Channel_2400W_Speaker_Subwoofer_Amplifier?gclid=EAIaIQobChMI3p204fCx3AIVQ6mWCh1wvQPgEAYYASABEgJqSvD_BwE#incar-amp-multi
Am I going in the right direction, or is there a better area money can be spent to achieve a better result from the same price range.
no telling price diff there.. those shallow mount subs aren't good man., if u have any room at all get a pioneer 3004 if u can (since u looking at pioneer and idk what else u have over there) idk the amp but we have a guy here that test amps on his youtube channel and we know that pioneer amps like the 8604, 8601 &9601 all do rated or more than rated power.. rockford prime amps are good.. maybe tell us what other options are and if u must use a shallow mount sub
Thanks for the post.
As I stated previously, it's a dual cab Ute with not much space.
The bigger area for space that I could fit a sub is going to be behind the rear seat, so a slimline is my only option.
As for amp, Can I use a 4 channel amp for the speakers an I have 1 channel to each side of the speakers and then bridge 2 channels together for the sub?
Is this the best way to run my system?
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
649
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
731
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
659
Sounds like me ...i should saved all those yanked Bose amps ithrew in the trash ..i couldve retired off ebay from them now .....lol
941
that was a pain... 2.5 days probably removing everything, cleaning entire area and doing it. ive only done trunk cars before this was def a lot...
14
Jacko-D22
Jacko-D22
Australia
Jacko-D22
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
