How many 4's make a 0?
  • 4
ThxOne
Premium Member
The Boss
I am now planning my next system build and it's going to be 3 amplifiers. Each of these amplifiers accepts 4 awg power and ground. I plan to use a 1 in 3 out distribution blocks for both the power and ground cables. I will be using 0 awg power in to the block. How many 4 awg cables will equal that 0 awg cable? Will 3 - 4 awg cables be ok?
I have an extra Knukonceptz 0 awg to 4 awg distro block brand new if you’re interested. Willing to sell it for cheap. I have no use for it.
http://www.knukonceptz.com/mobile-audio/distribution-fuse-blocks/sp/konfused-2-way-power-and-ground-distribution-block/
KonFUSED 2 Way Power and Ground Distribution Block - Merchandise
PM Me please
It's not about how many are equal. In most cases 2 4awg cables can carry the same amperage as 1 1/0awg cable
This is a blurred line with oversized audio wire but similar none the less.
At any rate 1/0 is typically fused 300-350amps for 20ft if your 3 or 4 or however many 4awg wires combine to a larger amperage draw than that you need bigger wire.
In my case I have 1 1/0 feeding 4 4awg but 2 are fused at 80amps, 1 at 50, and 1 at 30amps. Total I'm fused for 240amps which is below my 300amp main fuse. I still have room to up my 30amp fuse to 90amp if I need more juice for my relay board
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
