Dayton Audio Box Build
Enclosure measuring 36x15x15 for a pair of Dayton 10s..
Woofers firing forward and ports to the rear..
Any paint recommendations? Ports are already black.
Still waiting on the backordered woofers from PartsExpress..
It’s been awhile.
What vehicle is this going in? This just doesn’t make sense to me. I can’t see this going well. I really hope it works out for you tho. Otherwise you might have to get another box made.
4door sedan.. Firing from the trunk through a ski hole opening..
Box Design by Peter Kulicki @ AD Designs aka Hexibase.
The box looks good man. If that is a Hexibase design, then I imagine he had his reasons/calculations for doing the port direction like that and it's going to sound good. Can't wait to see some vids.
I hope it sounds great too.. Building boxes is pricey, super dusty and time consuming..
Priming the enclosure now.. Slapping two coats of Matte Royal blue with black ports.. And all black Dayton’s to match..
Peter Kulicki usually does good designs so I'm sure it will work. But traditionally I wouldnt ever put port and sub opposite. Unless It was like in a crx hatchback in which the cabin is so small cancellation doesn't have time to happen
A friend I know swears by PWK designs. I heard a folded horn enclosure that PWK designed. It was for a 12" Morel Ultimo Titanium. He tells me PWK has his own software that he made to calculate cabin gain and such. The response was pretty decent but I wasn't impressed with the output. Maybe it was the sub I'm not sure. I kinda feel it's a rip off for $50 but if it's for a complicated design then I could understand. There's alot of mixed feelings about this guy but IDK.. Was there a long wait time? I heard it was like a month or 2 wait for one of his designs.
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
Wiz Khalifla_85
Illinois for now
Wiz Khalifla_85
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
