Multiple sub placement
  • 5
Mellowmatt92
17
Arkansas
To start with. I am not looking for criticism on my gear. Most of it was given to me. I drive a 1996 intrepid. I currently have 2 alpine type r 12’s in my trunk running off an Infinity K1000. Yesterday I was given two 10’s in a truck box. I am going to hook them up just for fun. Should I put them in the trunk with the 12’s? In the back seat? Which way should I fire them? Etc etc etc. they will be run off they’re own amp, in they’re own airspace. Thank you for any advise
Never a good idea to run diff sized subs in a vehicle, and diff brands too. They will cancel each other out and won't sound good. The just for fun will turn into a waste of time.
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
6
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
Mellowmatt92
Mellowmatt92
Arkansas
shredder2
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
Latest topics
