8" sub recommendations
tooshort_128
I'm planning to install a budget system in my 2017 F-150 and finally want to try 4 8's. The box will be sealed and will have about .4 cubes per sub. My budget is at $200 so I was looking at some Skar IX-8s (cheapest option) and NVX VSW8s. Are there any other budget friendly 8's out there that will sound decent? I'm not concerned with spl but the lower they hit, the better.
if youre looking at 1.2 cu/ft sealed, why go with 8"s? you could get a very good 12 for around 200 and blow the 8s out of the water
I’ll have 1.6 cubes for all 4. Why not skar? Are they that bad? I’d be interested in the MB’s if they weren’t shallow. The subs will be under the seat down firing but don’t need to be shallow. Ive got over 5” of mounting depth to work with so full size subs will work. I feel like the shallows won’t have the excursion to hit the lows.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
474
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
329
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
477
tooshort_128
tooshort_128
Sterling, VA
shredder2
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
